Steering stabilizer - what mfg is the best?
I currently have a dual steering stabilizer from Rough Country on my '07 Unlimited. One of the bushings is bad and creating a wobble at 60 MPH (I assume it is the culprit because everything else appears tight). Can you purchase just replacement bushings - if so where? The second question is - who makes the best dual stabilizer kit out there. Should I just upgrade since I have to pull it off anyhow?
JK-Forum Founder
a bad steering stabilizer WILL NOT cause a wobble or anything else for that matter. if your suspension is dialed in, you technically don't even need one. you need to be looking elsewhere for your problem - have you checked your ball joints?
I have a single bilstein . The RC dual I had was a big hunkojunk, looked cool though.
I'd pull the whole thing off and see where your wobble is from.
edit: like eddie said.
I'll keep looking. Everythnig did seem tight but I will take a crow bar to it and see if I can get anything else to move where it should not. Either way, i do know for sure that the stabilizer bushing is bad. Its a start.....
