Steering stabilizer question
I have a 2010 Wrangler Unlimited with 3.25 lift and 35's. I changed the 35's off for the winter and put the stock 32's on. Changed back to the 35's now with 14k miles on the jeep. Seems I am having a little wobble in the front during certain speeds. I am thinking the width of the tires are placing a little extra stress on the stock stabilizer. What has anyone upgraded to? I do not see the need to add dual but will add a new better one.
Thank you for any input.
Mandor
Mandor
I've been using the Teraflex SS for 5 months and haven't had any problems.
Edit:
I used the Bilstein HD on my old Jeep and I can't tell the difference at all between the 2.
Edit:
Mandor
Mandor
If your JK is properly set up and torqued to spec, then you actually shouldn't need a stabilizer at all.
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
Thank you for your inputs.
I will go around and check the front but it all seems tight and true. There is no pulling to one side or the other. I am thinking I will let the tires round out after sitting all winter. The pressure is good all around and it is just a slight wobble in the steering wheel for a short band of speed. At 60 it is fine.
Mandor
Mandor
I threw on the teraflex stabilizer ...I had the stocks on and still had a slight wobble so I bought the fox racing stabilizer...never installed it. Put my 35's on and have no wobble with the teraflex on there. Mine defintly had to do with the tires.
Mandor
Mandor
