Is a Steering Stabilizer Just a Shock with a Fancy name
The reason I ask is because I have some extra Black Diamond Shocks and I was wondering if one of them would work as a steering stabilizer. I just put a 3 inch Black Diamond lift on my jeep with 35s. It rides fine under 50 MPH, but after that, the suspension is very darty. I am looking for something that will help it ride better at highway speed. I had the allignment checked today and everything was good to go. Will a steering stabilizer help???? And if so, will a shock work as a steering stabilzer or do I need to order a new one????
You can think of a steering stabilizer as a "mini shock absorber." A full size one, which is what I believe you said you have, will not fit in the location where the stock brackets are at (a full size shock is too big). If you want to truly fix the darty feel, what you want to look at is your caster angle. When you lift your Jeep, your caster changes from stock, giving you that feeling. To fix it, you need new front adjustable upper and lower control arms so you can dial in a bit more caster.
I picked up an after market (Superlift) Steering stabilizer and it seems to just be a big old shock but it does have a relocation bracket to make it fit.
Location: Apple Valley, California Good ole Mojave Desert.
You need to find out the root cause of your dartiness.Steering stabilizers just mask the problems you are having until whatever issue you are having gets worse and worse..
