steering shimmy
steering shimmy
what will tighten up the handling of my 2dr?i have just under 4in of lift on 35s. i dont get death wobble but when i hit a pot hole or uneven pavement while turning, my wheels jerk back and forth a couple of times and then stop. would replacing the drag link and tie rod do anything? trackbar?
Former Vendor
Have you found your issue? Do you need any assistants with the method of checking each item for looseness?
Feel free to e-mail me if you have any additional questions on how to correct your problem. I will be more than happy to assist you in any way possible.
Centering your front axle with the help of an adjustable track bar will help, if you haven't done that already. Then I would check steering components for wear, mainly ball joints and all the tie rod ends. There is lots of info on how to do that.
