Steering problems PLEASE HELP!!
This is a problem with the Teraflex Design. The design simply does not work. I have the same problem. You cannot move your track bar mounting point on the frame side without using a dropped pitman arm, yet for some reason they did.
Does not matter how parallel you make them, it still will not work. It might be better, but still wrong. The track bar and the drag link MUST be mounted at the same height.
Well
That just sucks!!! I've got alot of money invested and I just want it right. If there is something else I can buy to improve or fix I am willing to do so!!
![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
if you check tera's site they show a track bar drop bracket with the flip kit. i don't know if that is some kind of package deal or something they recently started or what. you may want to try to contact teraflex and let them know that you installed the drag link flip but no track bar relo. they'll be able to tell you exactly what part you need. i think it might need to be welded tho
AEV has the high steer tracbar bracket for the axle. i'm thinkin of getting a different one but that will give you an idea of what i'm talking about. as for the TF kit, it comes with both the tracbar relocate bracket (frame side) and the flipped drag link to mount on top of the knuckle. no additional parts needed as far as i know.
http://northridge4x4.com/proddetail....0405AA&cat=273
NO vibrations, just steering wheel moves and jeep kinda wanders with it. Also like I said, I can bounce on front bumper and watch the steering wheel go back and forth. That doesn't seem normal to me.
