Steering issues after Front axle truss & ball joint install
I try not to repost or ask useless questions until I have searched and attempted to fix on my own, but I am desperate and need help. Here is the low down...
I just finished up my front axle "semi" build which consisted of Artec truss, artect c gussets, inner axle seals, jks adj. bump stops, synergy hd ball joints, arb diff cover and fox ATS stabilizer. I also added some spidertrax spacers during the re-assembly.
The issue: now currently driving at any speed the steering never wants to return to center. I don't think I have a bump steer issue, this seems more like a wonder or pull but it happens to the left and the right. In other words, oversteer, if I turn left the vehicle wants to continue going left until the steering wheel is over corrected back to the right and if I turn right the vehicle continues to pull to the right until the steering wheel is over corrected back to the left.
This issue was not present before the axle build up and ball joint install.
Tire pressure is 30 psi.
I removed the spidertrax= no change.
I removed the fox ATS= no change.
RK LCA & trac bar is set to RK spec, so I assume caster is okay.
I've re-torqued all suspension components front and rear.
As stated above the jeep drove straight as an arrow before I did the axle work and angles were in spec when the last alignment was done 3k miles ago.
Have I missed anything?
Should I pay to have an alignment done to check caster?
Thanks.
Also, all of the products listed that I have installed have a great reputation and I don't think my issues are a manufacture defect, probably leaning more towards something I did during the install
Thanks.
You may have less than adequate caster after the lift. That, coupled with new ball joints that may not want to spin easily, will fight the self-centering force after making a turn.
Pardon my ignorance, but exactly how does RK specify to set caster? I ask because some kits just have a length measurement for the control arms just to get you started, but you're expected to set the angle properly after the install is finished. Also, any control arms/trackbars that you loosened during the job were not torqued down until after the Jeep was back on the ground with all four wheels, right?
Nevermind.... I looked at your pictures again and noticed you didn't raise the track bar mount. While it's less than ideal, it should be okay....
Is there an accurate method for checking angles myself, or should I have it aligned?
Is there a break in period for new ball joints?
Thanks for the info and help.
Up in the writeups area, you will find an index at the top. There is a DIY Alignment writeup in both the Steering and Troubleshooting areas. If the links are still broke, just scroll down. The Caster section shows a method using a cheap angle finder. This will not be as accurate as an alignment machine, but will get you some ballpark numbers to go on. (there is a more accurate location than the writeup shows, but I actually don't recall where it is. Maybe the pinion output? I'm sure someone will confirm the other location)
There have been quite a few posts indicating that the steering was very tight after new ball joints, and that it took a week or two, or a thousand miles or so, to loosen back up. Can't say for certain that that is what you are feeling, but it is not uncommon.
And if you have any local shops that offer free alignment checks, it wouldn't be a bad idea just to go in and get the numbers. Then you can post them to get some feedback on whether you want to do anything else.
More like ignorance on my part you are correct the RK spec is to set the length of the control arms, which I thought (that's what I get for assuming) was to set caster and pinion angles. The suspension was torqued on the ground after jostling the corners a bit.
wayalife.com/showthread.php?3861-Basic-Do-it-Yourself-Jeep-JK-Wrangler-Front-End-Alignment
