Steering issue...
#31
the synergy is worth the extra money because both ends of the draglink can be replaced. If the knuckle side end of Teraflex's goes, you'll be replacing the whole piece.
#32
OP I'd definitely go Synergy just for that reason.
#33
The Teraflex setup uses a drop bracket from the frame. Synergy uses a raised bracket from the axle. If you read enough threads here, you will generally find people indicating that raising from the axle is the better choice. (right or wrong, you decide...) Anyway, look past the "lowest price I could find", do some research on the options, and form your own opinion. (guessing that you would not have ended up with a drop pitman if you had done this )
Whichever brand you choose for your steering upgrade, consider sticking with their components rather than mix n matching. (one example - synergy redesigned their own trackbar to work with the optional brace. Using other mfg's bars has been hit or miss...)
#34
So, just to follow up to this issue and to let you guys know what I ended up finding. Before pulling the trigger on buying anything else I took the Jeep back to have the alignment re checked and they found that the caster and toe was off by a few degrees and corrected it for free due to it only being 3 months since I had it done originally. Got the spec results to keep for myself to show what was done. Still had lots of play in the wheel as I drove it home so I had my wife saw the wheel back and forth just between where the it seem to catch before the wheels turned. I noticed that the pitman arm was not moving fully when the sector shaft was. So I ended up tightening the pitman arm nut although it was torqued and Loctited when the dropped arm was installed. I got more turns than I expected when tightening and so I applied some torque stripe so I can Monitor whether or not it works loose. I then had my wife rock the wheel again and all was good but I plan on installing a Synergy sector shaft brace due to seeing some movement already. I just hope I haven't screwed up the gearbox already. But as of right now all is good and she drives like it was supposed to. Thanks to all for the advice and input.
#36
I would remove that dropped pitman arm and flip your draglink instead. That dropped arm is putting pressure and leverage on your sector shaft which is why it loosened in the first place. Just make sure you raise your tracbar at the axle side at the same times
#37
