Stalled in Water Won't Start
Old 03-01-2014, 02:33 PM
Desert Snow's Avatar
Default Stalled in Water Won't Start
Sorry, I wasn't exactly sure where to post this...
I just got towed out of a puddle that I hit too fast and ultimately had my stall out.
I pulled the air filter, which was wet but not dripping. I cleaned and dried out the box and eventually put the filter back in place.
The jeep will not turn over. It just gives a single click.
Electric works (radio, lights, etc).
Any troubleshooting tips besides letting it dry out (even though it's raining hard here in Phoenix)?
Old 03-01-2014, 02:40 PM
JKMedicPA's Avatar
Check your battery connections maybe. Thats all I have
Old 03-01-2014, 02:48 PM
JeepWranglerNation's Avatar
Default Low "Carb" Diet
Mind you checking the air filter is not enough, you need to remove the intake tubing which leads to the carb, Check all the small lines (rubber tubes etc) attached to the intake, Then mix a small amount of gasoline & methylated spirits (aka Denatured alcohol) and slowly pour a small amount into the carb along with other areas that may seem floored... don't over flow.. you just want to vaporize any water which maybe in or around your carb.
Old 03-01-2014, 03:08 PM
Thank you. I appreciate the feedback. I'm waiting for the rain to stop to get back out there.
Old 03-01-2014, 03:11 PM
TxRdStr's Avatar
May be hydro locked. Pull plugs to release any pressure and try to turn over.
Old 03-01-2014, 03:25 PM
Would hydro lock have the same symptom?
Old 03-01-2014, 03:33 PM
Unhappy Ouch..
Hydrolock - Wikipedia, the free encyclopedia
Old 03-01-2014, 03:36 PM
dcharge74's Avatar
Yes, everything you described would be a symptom of hydro lock. DO NOT start the motor until you verify that there is not water in there. Drain the oil. If it's milky, then you've got water in the motor. Pull the spark plugs and then try to spin the motor by hand with a breaker bar and socket. If it spins and water comes out, you may be able to save it. If it doesn't turn, then you most likely bent or broke a rod, and the motor is hydro locked.
Old 03-01-2014, 03:40 PM
dcharge74's Avatar
Originally Posted by JeepWranglerNation
Wow, I never thought to wiki that! Excellent description.
Old 03-01-2014, 04:20 PM
D_engel's Avatar
this would work well if we actually had carbs.
Quick Reply: Stalled in Water Won't Start
