Stainless brake lines rub on tire...
My extended brake line rub against the tire. I was thinking of slightly bending the metal tube that attaches to the caliper. It is curently bent outwards( towards the tire ) Anyways, before I do this I was wondering if anyone knows is this is the kind of metal that bends or breaks... ![what?](https://www.jk-forum.com/forums/images/smilies/aaah-what.gif)
Here is a pic:
Here is a pic:
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
![](https://www.jk-forum.com/forums/images/ranks/veteran_air_force.png)
Yeah, I had the same problem. Had to swap my lines around so the two with the bend were on the front axle and bent inward. You'd think the manufacturere would include a brief instruction sheet explaining that. I ended up rubbing through the clear outer sheath on two of my lines, so patched it up with "F-4 tape". Have no idea where one would buy that today, but it seems to have fixed the problem--no further symptoms after my run in Colorado last week! :-)
