Stacking coil spacers?
Old 06-11-2008, 04:43 PM
JK-KJ's Avatar
Default Stacking coil spacers?
I tried searching for the answer, but had no luck...
I have the Rough Country 1-3/4" spacer lift right now, but would like just a little more lift in the front...could I buy THESE and put them on top of the 1-3/4" spacers in the front? Or is that a NO-NO?
Old 06-11-2008, 05:43 PM
Renegade's Avatar
Stacking spacers on the front is pretty common. The bumpstop tower holds them in place nicely.
Old 06-11-2008, 05:45 PM
JK-KJ's Avatar
awesome, that's what I wanted to hear....thanks!
Old 06-11-2008, 05:51 PM
KnuckleHead's Avatar
Umm...technically you can stack spacers, but I don't recommend it and I don't know how many people would. I mean on the street I can assume you will be alright, but once you go offroading and begin to articulate, or take a sharp turn on the road, I don't doubt one of those spaces popping our or at least shifting over.
I wouldn't do it. If you really want more height than just spend the cash and do the OME lift or something. But stacking spacers isn't secure.
Old 06-11-2008, 05:58 PM
JK-KJ's Avatar
uh oh...tie breaker anyone? now I'm not so sure.
Old 06-11-2008, 06:04 PM
jeepin08's Avatar
I have a 2-1/2" BB With a 1" spacer stacked on top. I see no problems with this and when I installed the spacers they were fitted snug. I highly doubt they would work there way out. I have had this setup since December with absolutely no problems and would recommend to anyone.
Old 06-11-2008, 06:43 PM
Stretch's Avatar
If your worried about them moving around, weld them together.
Old 06-11-2008, 06:53 PM
jeepnyak's Avatar
i'm running the 2.5 bb from tereflex and a 3/4" spacer stacked in the front, no problems here
Old 06-11-2008, 07:17 PM
-MAW-'s Avatar
how do you weld rubber
like saying how much does air weigh?
Old 06-11-2008, 07:29 PM
Denny2565's Avatar
The Rubicon Express BB instructions tell you to use the factory spacers with their new spacers. They say you can put the above or below their spacers. I went by their pictures and put the factory spacer on the bottom up front and on top in the rear.
Quick Reply: Stacking coil spacers?
