Stack TF budget boost pucks?
I'm sure there has been a thread on this, but couldn't find it. I want to go with a teraflex budget boost 2.5" lift with shock extensions. I do want to get a bumper and winch eventually. Can I stack the budget boost puck, with a 1/2" puck on top of it? Anyone encounter this?
I don't wheel off road really at all, but it'll be for moderate off roading. I have an 07 jku.
JK-Forum Founder
i suggest you take a measurement before installing your lift and then one after and, if you still feel the need to install additional spacers, get ones based on what you really need instead of going off a best guess. yes, you will have to do the work twice but, you may find that you don't even need them at all.
[/CENTER]
That's true good advise, I probably won't get the bumper and winch for a year or so out after the lift and tires are put on. Are there comparable budget boosts to Teraflex that a bunch of jeepers use? I saw Rough Country, but TF looks like a more stable kit.
JK-Forum Founder
regarding budget boost, what can i tell you other than a budget boost is a budget boost is a budget boost. some come more complete than others but, for the most part, you can't really go wrong with whatever you go with.
