Squeaky OEM sway bushings
Old 07-12-2011 | 09:07 AM
scononie's Avatar
Default Squeaky OEM sway bushings
Hey guys,
About a month ago I installed my FT 3" SRS and have triple torqued/checked all bolts, springs seats, upper control arms, traction bars and the like. Everything associated with the lift I've touched. I love the way it handles and rides, but when hitting the small bumps in the road at slower speeds or off road, its a squeaky nightmare. I've accepted the fact that the draglink clunks and makes noise when hitting bumps but this is not a "Silent Ride System"
Any ideas would be appreciated.
Thanks.
Old 07-12-2011 | 09:28 AM
rizob's Avatar
Keep an eye on your bushings. I have read horror stories about them. Make sure it is not them squeaking. From what I hear it becomes pretty undrivable when they go.
Old 07-12-2011 | 09:58 AM
Northridge4x4's Avatar
Sponsoring Vendor
I have installed a bunch of these and have had zero issues since they changed to the "SRS" system .
Did you torque the arms once the vehicle was on the ground?
David
Old 07-12-2011 | 10:02 AM
Sponsoring Vendor
Thats old news with the old bushings no issues with the new Bushings at all.
David
Old 07-12-2011 | 10:06 AM
Hanson/PUREJEEP's Avatar
Sponsoring Manufacturer
Hanson/PUREJEEP Representative
Originally Posted by scononie
Hey guys,
I've installed my FT 3" SRS and have triple torqued/checked all bolts, springs seats, upper control arms, traction bars and the like. Everything associated with the lift I've touched. I love the way it handles and rides, but when hitting the small bumps in the road at slower speeds or off road, its a squeaky nightmare. I've accepted the fact that the draglink clunks and makes noise when hitting bumps but this is not a "Silent Ride System"
Thanks.
Did you tighten all the bolts at static ride height or did you tighten them when it was off the ground?
I run this exact same kit and have 71K miles on it with absolutely no noise at all. I did have a slight squeak that was coming from my rear sway bar D bushings. But a simple greasing of the bar fixed that quickly.
Old 07-12-2011 | 10:09 AM
Full-Traction Suspension's Avatar
Former Member
What did you torque the bolts too? What style of discos do u have?
Old 07-12-2011 | 10:36 AM
scononie's Avatar
Yes I have tightened all suspension components when the rig is on the ground to torque specs. After 500 miles after initial install I rechecked and re-torqued to specs.
As for the swaybar link bushings, I'll recheck those.
Old 07-12-2011 | 10:41 AM
scononie's Avatar
Front Uppers 75-76 ft-lbs
Front Traction 128 ft-lbs
Rear Uppers 126 ft-lbs
Rear Traction 125 ft-lbs
Front discos are my original rear swaybars
Old 07-12-2011 | 11:06 AM
Grease your rear sway bar D bushings.
What shocks are you running?
Old 07-12-2011 | 11:09 AM
scononie's Avatar
I'll do that tonight.
Bilsteins 5100s
