Sqaure Tube Connectors - Drawer System
With the crazy price of ready made drawer systems... 600, 1000,2000, etc... I'm looking at making my own but preferably not out of wood. Metal will last longer and be more durable and aluminum would save a ton of weight.
For starters, I can't weld so its either quick connects, pay someone, or bolt the whole thing.
I found these things Connectors Square Tubing - Corners L T 90 degree, 3 way, 4 way | EZ Tube - International Designs - Not the snap lock ones, but the pressure fit ones. Anyone have experience making something out of this for the cargo area?
I would keep your eye out for a used system.. I bought my tuffy security deck used for 300 3 years ago. With the removable plate for back seat- which follows the curve of the seat, and ability to remove the top so easy, let along lining up the end so closing it is flawless.. I think it would be more work than you think.
I have to play the devil's advocate and say despite it probably being more work and even if you work for minimum wage it would be cheaper to buy an already made drawer system it would be so cool to make your own! When it is super awesome and all your friends want one (or at least say it to your face while the opposite behind your back) you will dream of patenting your design and making your first million just making it for family and friends. Did I mention it would make you pretty cool...but at the end of the day you may feel differently about your decision.
Go to your local metal supply store to get some ideas on materials. I'd make a bolt together angle iron frame, you can cut the angle iron with a grinder. You could use aluminum sheet for the drawers, sides and top to save weight. You can use a cheap jigsaw with a metal cutting blade to cut out all your aluminum. I'd rivet the aluminum to the frame and add ball bearing drawer slides. For a little more security you could make the top of the box from stainless or cold rolled steel (then paint it). If you do that, have the metal supply cut your piece to spec. Sounds like a fun project.
I've found an example of someone using the stuff in the first link (or similar product from the UK?) on youtube.
https://www.youtube.com/watch?v=GaYrMPE9Td0 https://www.youtube.com/watch?v=rt7kqgRhgks Looks like it came out pretty well for him actually
Is this what you are looking for?
http://www.4wd.com/Jeep-Interior-Par...t_pn=S%2fB2763
I was considering building something myself.
