spyder or smittybuilt rocker body cladding protection
I was under the impression that the rubber padding they sell would end up being a tight enough fit once you tighten down the bolts that it would keep dirt or water from getting in between the body and the armor? If you've already got rock rails then definitely go with the aluminum. According to PS, they're 27 lbs. lighter than the steel.
if you're worried about rust you should get it professionally primed and painted. Do you really think something that you can peel off by hand is going to stand up to getting stuff thrown off the tires onto it?
