spray on bedliner duplicolor vs rustoleum
the duplicolor leaves more of a texture and seems to come out of the can as more of a spattered spray where the rustoleum is a smoother finish and comes out almost like a light mist. there is A LOT of overspray with the rusto. i won't be buying rustoleum again. i finished the can i started and returned the other three cans to get more duplicolor instead. go with the duplicolor
Am i doing something wrong? I used the rustoleum Liner on a test piece, 10" long of aluminum diamond plate. I scuffed it pretty well, not wonderfully but it is scuffed up and i sprayed it with the etching primer, waited 3 hours, then sprayed it with the liner. 10 hours later, i can effortlessly scrape it off with a fingernail down to bare metal.
Do i really need to wait 3 days before touching it? What on earth did i do wrong...
Granted i forgot to scrub with mineral spirits and properly scuff the surface but is that, that big an issue? (i did wash with soap/water)
I certainly do not wanna risk using this stuff on my rims if it really comes off that easy...
Dulipicolor all the way.
My grill, rockers, inner fenders and even my hood was done.
I put it to the test on my quad. The a-arms and pegs were done and didn't even show wear after a season.
autozone by me is a rustoleum dealer not duplicolor, thats where i got the 3 cans of rustoleum i bought. I think i am gonna go back and see if they will take back the used cans and go to walmart get duplicolor.
Originally Posted by Trauma
So what on earth am i doing wrong lol...
Where do you guys buy your duplicolor?
I just did another test piece.
Should i have cleaned with mineral spirits immediately before spraying the primer? I followed the directions and did this
1:Washed thouroughly with mineral spirits
2:Wiped off residue
3:Heavily scuffed the entire piece with scotchbrite
4:Wiped off dust
5:Primed ASAP. 3 light coats 2 minutes apart.
How long should i let it dry, before applying paint?
Also, i feel like i should have done another mineral spirit wash after scuffing, should i have?
2:Wiped off residue
4:Wiped off dust
2:Wiped off residue
4:Wiped off dust
2:Wiped off residue
4:Wiped off dust
edit: I also only let it dry for about 24 hours before putting all the seats back in
