Spicer ultimate dana 44 front axle
Old 12-03-2016 | 09:02 AM
Monte417's Avatar
Originally Posted by jtphoto JK
To start, The Cs aren't as weak as everyone seems to think on a stock JK axle. C gussets support the tube at the weld where the tube bends. The Military J8 Jeep runs those same Cs. The heavier tube on the new Spicer should be plenty. Google it and see if you can actually find a bent C . I personally took out a car with my front tire at 30 mph and didn't bend a C. The Spicer is still around $800- $1000 cheaper then a G2 last time I priced them.
I've said this before to you and I'll say it again the C's do in fact bend and are not "worry free" for trail use
Old 12-03-2016 | 10:18 AM
mo0s3's Avatar
Adding gussets to strengthen the C's is a relatively cheap addition
Old 12-03-2016 | 10:31 AM
jtphoto JK's Avatar
Originally Posted by jedg
hrm.. I now of two jeepers in my crowd that have bent Cs on their axles.
Chances are it's not the C, it's the tube. Have a good look. YJs and TJs had bent Cs, I have yet to see a bent C on a JK from anything other then a wreck ... Google it, see what you come up with. I have yet to see one, all I hear is " couple guys I know had Bent Cs".
Old 12-03-2016 | 10:34 AM
jtphoto JK's Avatar
Originally Posted by Invest2m4
The tubes are 1/16" thicker (5/16") and the same 2.5" OD. Wall thickness after .25" barely adds strength, it's all in the OD. To say another way, the tubes are still a serious weak point. Even if you truss, you still have a weak housing at the cast/tube connection. I built a G2 with an ARB and 35 spline RCVs for under $4k. I've replaced bent Cs.
Never said they were as strong or stronger then bigger tubes.
Old 12-03-2016 | 10:47 AM
Ryan0260's Avatar
I honestly don't see enough upside to this axle over stock for the money.
Old 12-03-2016 | 11:36 AM
jtphoto JK's Avatar
Agree. Other then better Locker and axle options. However, If you have to pay someone to build your axle for you anyway, you may as well just order a G2, PR, TF, or Currie complete unit.
Old 12-03-2016 | 03:41 PM
kyle521's Avatar
Right now the cheapest ive seen a spicer axle is $3000 with 5.13s, A new rubicon cheapest is just under 2000, but another 200 in parts plus labor to install the gears, so closer to $2500 when all said and done.
Spicer is at least $1,000 cheaper than any other after market d44
If I were to spend the money on a hd dana 44 front like dynatrac or G2 I would rather just put the money towards a 60.
Old 12-03-2016 | 05:54 PM
Punkineater's Avatar
I bent my C on the driver side and now have a Teraflex 44.
Old 12-03-2016 | 06:36 PM
Invest2m4's Avatar
Originally Posted by kyle521
Right now the cheapest ive seen a spicer axle is $3000 with 5.13s, A new rubicon cheapest is just under 2000, but another 200 in parts plus labor to install the gears, so closer to $2500 when all said and done. Spicer is at least $1,000 cheaper than any other after market d44 If I were to spend the money on a hd dana 44 front like dynatrac or G2 I would rather just put the money towards a 60.
Where did you see $3k? I'm not aware of any shops looking to lose money...
Old 12-03-2016 | 06:39 PM
kyle521's Avatar
4 wheel parts, Its listed at retail of $3800, Im not exactly sure they are losing money, its about 20% off. I feel like many of these axles are a little over priced, although I do understand the costs going into making them.
