Speedometer off in the wrong direction??
Hello all, just purchased a used 08 jku with 35" bfg km2 with a j-spec lift I don't know if it has stock gearing it's an auto. My problem that I don't understand is why my speedo says I'm going 70mph but by GPS I'm only going 64 65 mph? If I remember correctly when I put larger tires on the speedo would be off but it would say like 60mph but I would actually be going 70 or close to it. Any ideas on how to figure out what's going on.
Non rubicon
Non rubicon
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
Verify the gear ratio. (pull a diff cover and count teeth. -or- jack up one corner, mark the tire/ground and the driveshaft/housing, spin the tire two revolutions while counting the driveshaft revolutions. If you lift both tires on the axle, spin the tire once and count driveshaft revs.)
If you have access to the previous owner, ask if they used a programmer/tuner to set a new gear ratio or tire size in the computer. If not, I don't know how to tell what is currently set in there. Maybe just go to a dealership and have them flash it back to stock, then get your own programmer.
Hello all, just purchased a used 08 jku with 35" bfg km2 with a j-spec lift I don't know if it has stock gearing it's an auto. My problem that I don't understand is why my speedo says I'm going 70mph but by GPS I'm only going 64 65 mph? If I remember correctly when I put larger tires on the speedo would be off but it would say like 60mph but I would actually be going 70 or close to it. Any ideas on how to figure out what's going on. Non rubicon
My wife's uncle had the same problem on his Jeep. When I plugged the tuner back in I found the previous owner had entered his measured tire size as 35in. No tire is 100% true to size, especially under the weight of the vehicle. The tires measured 33.75in under the weight of the Jeep. I corrected the measurement entered into the programmer, re-ran the adjustment, and now his speedo is on to within 1mph at 70.
This is most likely your problem.
Happy Jeeping.
Happy Jeeping.
I'll check the axle ratio using that method. I'm thinking previous owner reprogrammed the computer...could I essentialy buy a programmer and reflash to the proper size even tho it's probably not on stock settings.
![](https://staticssl.ibsrv.net/autocomm/Content/JK-Forum/jkamicon.png)
If it was programmed withe the wrong gear ratio you would be in limp mode. My guess if speedo is that far off it was not programmed for the tires. Get a programmer and set it for current tire size.
Non rubicon
Non rubicon
I suspect that your numbers for speed are slightly closer than what you have stated here or the computer is programmed for 37" tires. A few decimal points on the speed readings matter when doing this calculation. You might think about using an OBD2 tool to get the exact numbers. I use a program called Torque on my Android phone with a Bluetooth OBD2 connection.
https://www.amazon.com/dp/B00WPW6BAE?psc=1
Note: Don't leave the OBD2 tool connected to the port under the dash all the time. It may run your battery down.
Happy Jeeping.
Happy Jeeping.
Bingo
