Spare Tire Mount
Old 09-20-2010 | 08:20 AM
larenta's Avatar
Default Spare Tire Mount
Hi..
I recently replaced my stock wheels with Raceline Beadlock wheels, which are (aprox) 3 inches offset. The issue here is that unlike the stock wheels, the spare (with its offset) does not sight tight up against the rear door. it's supported by the three lugnuts only.
Oh, and doesn't look very good.
Has anyone solved this issue? Is there a way to get the wheel closer to the door?
Thanks..
Lou
Old 09-20-2010 | 08:31 AM
JayhawkJeep's Avatar
Veteran: Navy
Your best option is get a tire carrier. The next option would be get a spacer for the stock carrier.
Old 09-20-2010 | 09:03 AM
Harbourone's Avatar
You can get Daystar isolators which bring the door to the tire (kind of). I would just ditch the spare until you can get a tire carrier though, my factory spare wore out the hinges on my gate.
Old 09-23-2010 | 07:33 AM
larenta's Avatar
Default Tire sticks OUT
The issue is that the wheel does sit on to the lugs, but there is a space of like 3 inches seperating the tire to the door. I would need the opposite of a spacer ( if it existed )
Old 09-23-2010 | 07:48 AM
tslewisz's Avatar
The Daystar Tail Gate Bumpstops (spacers) add to length of the rubber bumpers on your stock carrier.
Old 09-23-2010 | 11:18 AM
Harbourone's Avatar
Originally Posted by larenta
the issue is that the wheel does sit on to the lugs, but there is a space of like 3 inches seperating the tire to the door. I would need the opposite of a spacer ( if it existed )
DAYSTAR ISOLATORS
http://www.daystarweb.com/productdet...?productID=381
Three people have told you this.
Old 09-26-2010 | 05:33 AM
larenta's Avatar
Default Got it!
Originally Posted by Harbourone
DAYSTAR ISOLATORS
GREAT!! Did'nt catch it from the first "THREE PEOPLE", but when I followed the link and saw the product, all was clear. looks like the right solution for now, while I get thre ca$h for the tire carrier.
Thanks alot guys!!
