Spare Tire Carrier
Old 04-30-2014, 08:48 PM
Roryslife's Avatar
Right now a former owner of this forum is writhing in pain at the recommendation to get a Teraflex tire carrier. The dude in question hates them.
You can also probably get away with just running a spacer on the stock carrier, but if you do, make sure you get some extended isolators (I think Daystar) runs them.
I have the Teraflex hinge, tire carrier, and accessory/hi-lift carrier and love it, but it is expensive.
Old 04-30-2014, 08:53 PM
DallasJKU's Avatar
Knowing what I know now about that moron makes me appreciate my purchase even more!!
Old 05-01-2014, 02:38 AM
metaldemon's Avatar
I bit the bullet and put on the AEV carrier that mounts to the frame. It opens with the door. I really didn't want to put that kind of weight on the sheet metal tub either.
Old 05-01-2014, 03:35 AM
AnvilX14's Avatar
Originally Posted by pasteris71
It will eventually sag the rear door to a point that it won't open or close. There are a few ones out there like Tera Flex and Smittybilt that make an inexpensive mount to handle a 35" tire.
Proof please?
Old 05-01-2014, 05:26 AM
TreyJK's Avatar
Another vote for OR-Fab's Swing Away Tire Carrier, it's solid, good looking, extremely versatile, and cheaper than Tera Flex. Send me a PM if you have any questions!
Old 05-01-2014, 05:37 AM
robsjeep9's Avatar
Genright aluminum tire carrier ... Light, looks great and after all the problems with the Teraflex welds breaking even tho they fixed the problem so it's said I wouldn't trust it with my light 37" MTR .... Every other week someone's trying to sell theirs so if you wait you can probably save a few bucks ..... and probably ok with a 35" tire..... But my vote still goes to Genright.
ID:	549859   Click image for larger version
ID:	549860   Click image for larger version
Old 05-01-2014, 06:19 AM
ToolManTimTaylor's Avatar
Originally Posted by AnvilX14
Proof please?
Spot welds break on the sheet metal of the tailgate body and depending on use hinges sag with oem carriers and heavier than stock tires. It's a known issue.
Old 05-01-2014, 06:33 AM
AnvilX14's Avatar
My bad. I thought you were saying that using the Tera flex hinged carrier would result in tailgate sagging. The reason I bought the hinged carrier and tire mount is so my gate wouldn't sag and break.
Old 05-01-2014, 06:57 AM
Sponsoring Manufacturer
TeraFlex's Avatar
FYI I still run a Gen 1 version that is unbraced or modified with a beadlocked 37" MTR with zero issues for over 2 years. So the current beefied up version doesn't have any issues what so ever with welds breaking.
Old 05-01-2014, 10:36 AM
Work in Progress - JK's Avatar
I have been running the Hanson Tire Carrier for over 4 years, wheel several times a year and no drop in tailgate.
The Hanson mounts to the hinge and then to the original mounting points of the OEM - I like the fact that it's attached to the gate, so no need to have a pin and double swing.
Name:	My JK lifted 003.jpg
Quick Reply: Spare Tire Carrier
