spacers and vibtation
Sponsoring Vendor
try rotating your tires, see if it changes anything.
I have rotated tires and had them rebalnced about 5 times know. Even went to another shop and paid them to balance them. Could a steering stabilizer be in my near future? The steering wheel wiggles back and forth like crazy at around 5o mph and wiggles less the faster I go.
Check your ball joints. Also make sure all your tie rod ends and drag link are tight. A steering stabilizer only masks the problem. You may also want to remove the bolts from your front trackbar and check if your bushings have wallowed out. Then replace with 2 grade 8...3 inch shoulder bolts...size 9/16ths x 28 ( fine thread) and stover lock nuts. Torque to 150 ft lbs while the jeep is on the ground.
Damn ipad is a pain to type on sometimes
Phones do not type very well. I have a keyboard with mine and I still mess up. Will check everything for tightness and swap those bolts this weekend.
Just to update everyone. I swapped my moms tires onto my jeep with spacers and went down the road a few miles. No vibration. Having them replaced by comoany. Hopefully next set will do better. Did check track bar for track bar for tightness and it was good. Still gonna replace bolts in it. I did notice that my trackbar has some give to it when turning the wheel. Not sure if this could be the problem or not. Thanks everyone
First thing, rotate the tires front to rear. If nothing changes then its not the wheels and tires (or there is more than one wheel/tire with a problem). If there is a big change, look for a bent wheel or a bogus tire.
Remember that a balanced tire is not necessary round, and the plies in the tire are not necessarily running in a true line with the direction of travel. I've had a bunch of tires that were still bogus when balanced.
If wheels and tires can be eliminated by swapping them around, then there could be a bent axle or spindle.
I've also had the steering wheel work back and forth when a brake caliber drags and heats up the brake disk, but that problem comes and goes - its not always there.
