Spacers safe or not...post best argument here!
#32
Maybe try this: http://project-jk.com/jeep-jk-write-...top-adjustment
I did this fix and it works great, cost less than a $1.00. I'm running 285/70/17 BFG KM2's on a stock 2010 Rubicon. No more rubbing. I have not tested this off-road yet, but on-road it works perfect. It's a cheap and safe fix that will buy you some time and keep your tires from getting chewed up. BTW... I did not notice any difference in my turning radius. This will take all of 5 minutes and if you don't like it will you be out the price of a candybar.
FYI. You do not need to take the wheels off for this fix.
#33
Thanks everyone for your input...now that I've seen those mamba mr-1's I might go that route...but I think I'll try adjusting the steering stops first, as someone mentioned if I don't like the result I can change it and I'm out only some washers. Not sure how this would hold up off road though, plus I just discovered yesterday that I can barely get the tip of my pinky in between the rear tires and the frame of the jeep, seems far to close there?
#34
Take your wheels back and get different ones. They told you they'd work and they obviously aren't. Is that an option? I would like to think so, after all they are at fault. That's what I would do if I wasn't able to get some spacers for whatever that reason would be.
Sent from my ADR6300 using Tapatalk
