Spacer question
Spacer question
I ordered some 1.5 spacers and unfortunately they're taking a while to come in. Is it gonna matter if I I install the tires and get the alignment done before the spacers are on? Also worried about rubbing. My jk has a 4" lift and I'm putting 315/70R17 on stock wheels. Feedback appreciated. Thanks
Wish I had know, sent my wife to get tires put on and 4 wheel parts talked her into those spaces. with the rock krawler kit and aev wheels its got an 1.5" in the rear between the sidewalk and upper control arm they told her it was to close. If yours fit you will probably rub when you turn if that happens drop some washers behind your stops. I used the alignment directions on project jk.
