Spacer Lift w/ 275 70 17
I'm planning on an AEV 2" spacer lift with ko2 275/70/17's. Anybody else have this setup with photos.
I have a sport unlimited w/ 3:73 gears.
I'm also considering same tire 285/70/17's
Any thoughts and photos would be appreciated.
As long as that tire isn't wider than 11" you are good.
If I had it to do over again, I would still go with the 2.5 vs. hockey pucks.
https://www.jk-forum.com/forums/modi...2/#post4190983
Running the AEV 2" spacer lift with 285/70 R17 Duratracs. The only other mod I made was 2 washers on each steering stop. No rubbing, no issues. I haven't disconnected the sway bar yet though....
