Spacer lift
Spacer lift
Hey guys I am brand new to the Jeep world, I have always been into go fast toys. I want a 2.5 inch lift but dont have the funds right now. I have a 14 JKU Sahara. I was wondering what the thoughts are on a 2.5 spacer lift, and what else is needed to run that set up.
I have a 2.5" teraflex budget boost with shock extensions. I run it with the teraflex exhaust spacers so the driveshaft won't hit the exhaust crossover pipe at full droop when off road.
The Rock Krawler leveling kit will get you about 2" in the front and 1" in the rear. Comes with sway bar links for $200. Nothing else needed.
If you go with something like a Teraflex spacer lift, you'll get extended sway links for the rear and reuse the rear links in the front. I know lots of people that run with this lift.
If you don't wheel very much or are not aggressive, either of these will be fine. When you start crawling on big rocks, you'll want more.
I currently only have a RK budget boost installed and wheel on rocks (although nothing huge) with no problems. If you can't afford a full suspension lift, but REALLY want a lift, these will work.
The teraflex leveling kit has new links for the front not the rear. and its an awesome setup....its what I use and I love it. 33's fit perfect and gives a nice look for the money.
Teraflex Jk Wrangler 2.5" Performance Budget Boost
Rancho 2" sport. Comes with front springs, rear spacers, rear brake line relocation brackets, and RS9000 shocks. Basically, you are buying shocks and getting the lift for free. I didn't like the idea of spacers in the back, but i've had zero issue at FULL flex. 400 bucks with mail in rebate. 3 hour install with a buddy and a few beers. Faster with out the beers.
TF spacer level kit here. 2" on the front and 1" out back. Very happy with the product, the look and stance with 33s and RR wheels.
No rock crawling for me, light trails and DD. Can't beat the price point, and straight forward install.
Will upgrade to a BB 2.5 or coil lift in the future, for now this fits my needs.
What size tires are you planning on with the 2.5" spacer lift?
