spacer in front
spacer in front
ordering lift wheels and tires within the next week, finally!! i was going to put on a 1/2" or 3/4" spacer up front with my 2.5" teraflex spring lift with shocks.
2-door jk x (will have 17x8 wheels and 33" tires)
what are your suggestions on size of spacer?
what brand spacer should i use and where should i buy them?
thanks
jtr
thanks
jtr
thanks
jtr
thanks
jtr
http://www.quadratec.com/products/16117_1002.htm
also - keep in mind since you bought the TF shocks, you'll be installing the 1/2" spacer/spring guide in the rear to keep your coils in tact during extension so I would go with the bigger front spacer to offset that additional lift in the rear.
Do you have pictures of your jeep?
I have the same setup and went with 3/4" Skyjacker spacer on top of the 2.5" TF coils to compensate for the weight of the aftermarket bumper and winch.
wow, you lost me. lol
i will need to use all the things you didn't use, correct?
That being said if you don't want to have front end rake with this coil kit especially if you plan on adding weight to your front end (bumper/winch) then you could go ahead and install front spacers as well that I mentioned in the earlier post. If you do I would go at least 3/4" if you add a bumper/winch.
Wow, what extended help; I really appreciate that. I did order from David at Northridge and I ordered the TF 2.5" coil lift with shocks. I didn't, nor did he, which shocks I would be getting. I assume they are the 9550's. I'm having my lift guy put this on and I'll make sure and send him this post. i also got the 3/4" front spacers as well. Is there anything else besides the lift ordered and the front spacers that you found you will need at the time of install?
Thank you a bunch. I'll post pics when finished.
JTR
JTR
Sorry...let me try to clarify. In your kit you will get two rear 1/2" coil spacers that should be used if you got the optional TeraFlex 9550 shocks. Since you are installing the 9550 shocks you WILL NEED to install those rear spacers or else you will have this problem under full extension. Long story short...those 9550 shocks work for up to 4" of lift and they are long enough to allow you rear coils to fall out with the 2.5" coils.
JTR
JTR
Aside from that...enjoy your lift and post pics
