Sorry if this has been covered but...
Will 35's clear with a 2in BB lift? Also lookin at cragar soft 8 15's with 4 in BS, any input will be appreciated, I'm not too worried about doing minor trimming
This was taken from the FAQ at the top of this page:
Q: What size lift do I need to get in order to fit 35" Tires?
A: I would recommend a minimum of a 2.5" budget boost but a 3" lift would be a better fit. You can also install a 2" budget boost and 1" body lift to get you there as well.
https://www.jk-forum.com/forums/show...272#post211272
Originally Posted by Battlefrog
The answer is yes, a 2" BB with trimming your fenders will allow you to run 35's. As for 4" of BS, the answer is yes as well...
Originally Posted by RubiBus
I'm running 37x12.50-17s on a 2.5" coil lift with trimming, so I would expect 35s to work on a 2" BB.
I use 2,0 BB and 35x12,5.
Before fender trimming, it rubbed when flexed off-road, no problem on-road. It is my DD.
After stock fenders chopped, I can flex with sway bar disconnected with NO rubbing!
