Some help with my stage 1 build up
Can I get away without buying HD CVs, gears, axles, etc, with this stage one build up?
2 Door Rubicon
4" lift with shocks (stock control arms)
17x9 wheels with 4.75" backspacing and -6mm offset
37x 13.5 or 12.5 r 17 tires
2 Door Rubicon
Your driveshafts (rear and maybe front) won't last long on with the 2 door's short wheelbase and steep pinion angle.
You'll likely need adjustable control arms and driveshaft(s) soon.
From what I read anything over 2.5" you should begin to think about adding trackbars and such. I guess the 2 door is a little different from 4 doors as far as what you need when lifting and big tires.. Be sure to research before you go with any set up.
I'm not a big body lift fan. The 3" kit I chose is Black diamond with a new front track bar, and I'm going to buy the full traction rear track bar at the same time. I figure If I do the 3" now, I can get some tube fenders later for stage 2 and put on some 37" tires, driveshafts, gears, and axles then.
