SOLID Front Axle Hub Conversion Kit - Available & Installed!!
thats not really high at all, Warns hub conversion for the TJ is $1,183.99. Solids comes with new Disc's. The JK's ESP is also built into the spindal, thats more maching to the hubs for the JK than other jeeps.
the kit comes with extremely high quality 30 spline outters. Also your Rubicon 44 has stock unit bearings, a non-serviceable item. If that goes out on the trail your stuck literally...
The Solid kit was well thought out. If I break a shaft and destroy the lockout hub,. I can go to any autopart store and get a Chevy 44 outter (20 spline, and the hub) or just get rid of it. Most people on the trail will have a 19 spline stub shaft and 19 spline lockout as spares. Just borrow one of them.
Good luck getting a new unit bearing from the local autozone, the factory ESP sensor is built into it. I cant imagine thats going to be cheap to replace.
But what really sux is that for all of us that have gone out and spent money on wheels have thrown our moneys right out the window and will have to buy new wheels to fit. So $1200 for the conversion and another $800 for rims and another $30 a tire ($120) for mount and balance we're talking $2100+ plus labor but most of us will install them outselves. But still $2100+ for hubs is kinda crazy and if you brake it in the boonies will the local parts store or dealership be able get parts to get you going again the same day or will your rig have to sit a wait for them out in the middle of no-where. It's great that someone made a hub conversion kit but couldn't they have made one that would work with the existing hub assembly?? Sure 5 on 5.5 is better and stronger than 5 on 5 but for that amount I will get myself a Front & Rear bumper and a real good winch.
so just to make sure i'm on the right page... with this kit, you basicly get new parts from the diff out? new shafts, new hubs, new bearings, etc? so is this kind of like buying on the the Supior axle shaft upgrades but you also get the locking hub feature?
i will admit that this sounds awesome if it can make the front shaft unlockable and still retain all the computer controlled features so that the Jeep won't go bezerk. Sounds like a fair price to me, guess its one of those inital investments that go a long way.
Just to clarify. My question was serious. I wasn't trying to be difficult or sarcastic. I really want to understand how this is a must have. I imagine you'd get some benefit in MPG if you unlock the front shafts. But, other than that and yes the potential emergency limp off the trail...
With your stock axles, if you break an axle or ujoint on the trail, you can pull it out and just run the outer without the inner. it is a pain but it will get you home.
JK-Forum Founder
Once again, I apologize for my initial enthusiasm and have since edited my post to read, "I can tell you that this is going to be an upgrade that a lot of guys I know will want."
You know I think this is a pretty good idea for a JK. MPG will certainly go up, how much is unknown, but I guarentee it will, as those axle/driveshaft/tcase input parts will not turn anymore, resulting in both a whole lot less driveline drag AND wear (4 wheeling causes sudden breakage, not longtime wear, and Ill bet it will add to the longeevity of ujoints/driveshafts and axle seals as well). I have 3 guys at home in Maine off the base waiting for this, 2 just because I touted certain gas mileage increase (small side Jeep business Ive got). I do have some questions as to any track width increase (scrub radius definitely has an affect on both handling, the effect of power steering in the rocks, and both ball joint/wheel bearing wear)?? I tried to call Matt back before I deployed to ask those questions, hard man to get ahold of. I also am wondering if it doesnt increase the track width, if anyone knows if there is enough material to simply redrill the stock rear axle flange??? (if there is additional width, can matching width spacers with the appropriate wheel pattern be found??) Lastly, the rotors come with the kit, can they be "made" later when a brake job is neccessary?? (Lets assume it is either not cost effective to mail order rotors from solid, or prior planning did not come into play).
The stock Rubi front axle wouldnt be bad at all, if someone could come up with some cost effective trussing for the weak tubes, and some weld on bracing for the inner "C"s. Think of it, 30 spline chromoly outers, the better Rubi ujoints (hopefully some aftermarket ones will be available soon, especially with this, they wont turn on the street anymore, so you could go with a bushing, CTM style, instead of needle bearings) some stout 33-35 spline inners, and a matching Detroit/ARB/OX.............just some food for thought. I certainly wouldnt want to do it all at once, if I did that, I would just invest in an aftermarket D60, but to be able to upgrade when stuff breaks!!
