Soft Top Rack Options JKU
Ok fellow jeepers. Just bought a fishing kayak the other day. I need options on roof racks. Obviously the top will have to be down. I know there is the gobi option but I don't want to run that option all the time. Especially with top down. And it doesn't look easy to just disconnect the rack portion. Is there something out there that I can keep assembled and just throw up some mount brackets on roll bars when I need the rack? Another curve ball. Don't have room for trailer option :( ...... Anddddddd GO!!!
Thank you
Thank you
Olympic might work out for you. http://www.quadratec.com/products/12137_140X_PG.htm
Yes easy to remove! 8 screws remove the basket, 4 bolts to remove legs, you can leave brackets in place or 6 screws to remove fronts and 4 screws to remove rear! Or 4 screws to tilt back to open soft top!
