Soft Top Minor Repair / Mod Help Needed..................
Old 09-26-2011 | 11:00 PM
RKracing's Avatar
Default Soft Top Minor Repair / Mod Help Needed..................
2010 2 door Rubicon.....
The rear area will not stay down......or tucked in....
Has anyone modified this?
Thanks.
Old 09-26-2011 | 11:24 PM
D_engel's Avatar
same problem here. I just push it back in every few days.
Old 09-27-2011 | 05:37 AM
mkjeep's Avatar
You could try tweaking the bow brackets on the sport cage up abit. I backed my jk outta my garage with the door partially down, knocked it off the rails, bent the g door and the bows and brackets on my top. The rear area like yours was hanging about 2in lower than yours, wheras before it was super tight. I ended up getting new brackets but since the bows were bent and because of where, really no way to get them straight. I ended up tweaking the brackets up abit using a combo of vise grips and a crescent wrench. I left the brackets attached to the bar then tightened the crescent on the dip in the bracket and nudged it up abit. You can't bend it up very far but it may help you get it abit tighter.
Old 09-27-2011 | 05:48 AM
J-VET's Avatar
Veteran: Marine Corp
you might be able to create a shim with a small peice of plasyic or cardboard.
Old 09-27-2011 | 06:08 AM
big c's Avatar
Is this a big deal cuz mines the same and never had problems
Old 09-27-2011 | 06:21 AM
RKracing's Avatar
I guess it was a "big deal" enough for Jeep because they redesigned it on our 2011.
I was thinking of maybe adding some kind of a snap type button on there...........
Quick Reply: Soft Top Minor Repair / Mod Help Needed..................
