Soft brake pedal
Alright so just to make sure I understand this correctly. I use the ecu reader to check for the abs error then bleed the base break system. Clear the codes and rebleed the base brakes again continue this process until the brake pedal hardens. Sounds like I'm going to be going through a lot of brake fluid. Thanks for the info
