so where is the hp?
#21
The Magnuson with 3.6 Manual Trans is not bad at all, probably as it should be from the factory. Does not push you back in your seat.
Waiting on Robbi at MoTech to quote me the Baby Duramax and 6L70, would also consider doing an L86 (Gen V LS) with 6L80E or 8L80E.
You did right by going the V8 route. Most with automatic transmissions have major tuning issues, I did not; smooth tune with very good power delivery and I still miss my old 350ci SBC in my old 76 FJ40 because it had torque way low and power everywhere.
#22
some are getting me wrong here. I'm not complaining that it doesn't have enough power. My question is DOES IT HAVE 285HP? It definitely isn't as quick as my 2003 full sized chev pickup was with the same hp same gearing and more weight. Bottom end, midrange or top end it sure takes a back seat to that 285hp ls.
#23
#24
just looked it up the jeep puts out 250 fp of torque the o4 ls motor has 325fps. that's a pretty good increase and both make peak torque around 4000 rpm (to high) I would have to say that putting out the exact same hp with 75 ft lbs less torque kind of shows that jeeps hp rating isn't really accurate. I know hp and torque don't allways go up equally but it usually a lot closer then that.
#25
Don't ignore displacement.
#26
displacement has little to do with it. Look at the ford ecoboost for example or compare a v6 Camaro to a v8 Camaro from the 80s and 90s. Look at a truck my father had. A 90s ss454 chev. Lots of displacement there. Barely made 200hp. About any 4 cyl motor made today has that much hp,. Now granted using the same technology you will make more power with more displacement but that doesn't really factor into this unless were talking a stock 3.6 compared to a stroked one. Only thing I'm saying is that 280 hp isn't happening here. Id like to see one tested on an engine dyno
#27
#28
The LS3 (Gen IV) and L86 (Gen V) are well above 400 hp/torque at the crank.
#29
HP = (RPM * TQ) / 5252
You can plug both of your engine specs in and see the differences in the curves. Also lookup the peak HP RPM for both motors to see the difference.
#30
Pull the engine out dyno that bad boy. The burden of proof rests with you.
I will add that turning heavy wheels and 35s, I believe the crank HP rating. It's reasonable power for a brick.
