So what do I do now
So what do I do now
I’ve added a Rockhard4x4 stubby bumper with an Engo 10K Synthetic line winch to the front and an OR-Fab Standard bumper to the rear which puts a lot more weight on my stock springs. So I’ve been thinking of upgrading the springs to something that will handle the extra weight.
There in lies my problem. I thought I’d just upgrade with the higher rated Mopar springs, 19s and 60s since I’m currently running 14s and 54s (JK Rubicon Auto with HardTop) and using the stock Rubicon shocks because I really didn’t see a need to upgrade a perfectly fine set of shocks. But now I’m wondering if I would be better off getting an OME 2in lift or a 2.5 Teraflex kit with spring and shocks?
I really don’t need a lift kit I have Bushwacker Flat Fenders and don’t plan to run anything larger than 33s when it comes time to replace the tires and may just stay with the stock Rubi tires as I like them a lot so far. But I need to do something as the extra weight needs to be compensated for. So I’m asking:
“ Please ole wise ones throw some advise my way.”
Well considering that you are not planning on really going up much in tire size and where you are located. I would probably just add some coil spacers and call it a day. That will bring your ride back to they height you are looking for.
I say spacers over new heavier shocks because you will keep a softer ride with the pucks over the heavier spings. The spacers are basically just taking up the preload you have on the compressed springs you have now. This means you keep the same nice soft ride you have now. If you add heavier springs to stop the sag from the heavier bumpers so you dont get the sag in the first place you are going to feel the difference in the ride to be much harsher. You can think of the coil spacer as a ghetto preload adjuster if you will.
A standard lift kit is also an option as well but will be much more costly and for your application and tire size it is probably just not needed.
I agree, I would go with a cheap solution like a 2" Budget Boost from any major company if you don't plan on going higher than a 33" tire (which is originally what I said, then I wanted 35's). If you a DIY kinda guy, the bb's are very simple, all you would need done professionally is an allignment afterwards.
I personally have a Daystar 3" lift, it uses the factory coils with spacers, and new shocks. It was a very easy install, and only $200 for an allignment. I has a very smooth ride now, and I'm rockin' 35's...
Get new springs. Save your shocks. Most companies will sell you just springs. Maybe consider the teraflex performance leveling kit? It's a spring based kit.
http://www.teraflex.biz/jk-1-5-perfo...eling-kit.html
Longer shocks usually means an eventual need for new driveshafts, especially if you ever high center or flex a lot while disco'ed.
