So a stock JK 2-door can fit 32s. My options aren't exactly that.
Old 07-17-2011, 10:51 AM
gump9005's Avatar
Default So a stock JK 2-door can fit 32s. My options aren't exactly that.
So I'm looking at the Hankook DynaPros: http://www.discounttire.com/dtcs/tir...97006&pc=11959
Two options are:
LT285/70R17D1 121Q B which equals 32.70"
and
265/70R17 which equals 31.60"
When they say 32.70" do they mean with the tire over-inflated way past where I would normally inflate it just to get to that measurement? If I were to inflate it for road driving to a reasonable pressure might it measure closer to 32"?
I want a tire that won't require me to mod anything.
Old 07-17-2011, 11:14 AM
photographix33's Avatar
My Jk 4 dr. came stock with BFG 32's, I don't see why 2 door should be any different.
Old 07-17-2011, 11:47 AM
Phishjeep's Avatar
You'll probably be fine with the bigger ones. Its not that much of a difference.
Old 07-17-2011, 03:20 PM
Shadow's_Jeep's Avatar
If you really don't want to mod anything, then go with the 265/70R17 and you will be fine.
Old 07-17-2011, 04:09 PM
woodweavil's Avatar
Two options are:
and
You will be fine with the 285s
Old 07-17-2011, 06:36 PM
coltc2000's Avatar
the 285 fit any jeep that came with 17'' or 18'' without a problem only slight rubbing on front sway bar at full lock. most who have upgraded go this size with no problems and no lift
Old 07-17-2011, 07:02 PM
remingtonJK's Avatar
I am running 285/75R17 dynapro mt's on my 2dr. They are great for all conditions ( rock, mud, sand, ice). I'm running 28 psi on the street and 10 on rocks with the factory steel wheels. The only draw back is they are 10 ply so they are Heavy.
Old 07-17-2011, 08:02 PM
gump9005's Avatar
And they don't rub at full flex disco'ed?
Old 07-18-2011, 06:40 AM
guyp3's Avatar
Stock JK should fit 32's no prob.
Old 07-18-2011, 06:47 AM
orfanidisnikolaos's Avatar
either size will work
Quick Reply: So a stock JK 2-door can fit 32s. My options aren't exactly that.
