So So Confused man.... stock 18 rims
Old 02-10-2011 | 12:32 PM
  #21
Xnight's Avatar
Originally Posted by resQace
I've got the same dilemma goin on with my Sahara...just got off the phone with Teraflex and was told that I wouldn't have any interference issues running 295/70/17 tires on wheels with 4.5" backspacing when using their original spacer style leveling kit.
Looks like I'll be going with the V-Tec Raptors and Nitto Trail Grapplers in the sizes listed above...last I checked, entire package was going to run around $2,000 or so....for what it's worth! Good luck!
Is the leveling kit same as BB?... by that i mean lift height and price, because i wont discard going to 17" rims if it stays within my $2100 budget.
Thanks for the input anyways man, its worth a lot.
Oh and while we are at it... what are the implications of adding one inch of body lift?
Old 02-10-2011 | 12:43 PM
  #22
Jollydodger's Avatar
Originally Posted by Enzo
285's are the widest tires on the stock gladiator runs.275's are definitely going to fit, with no problems.295's will rub on turns. You will need spacers or less back spacing.
295's will barely rub at lock, it touches the swaybar as I recall, and doubt it would have any real impact on your life. Spacers will allow lock to lock clearance and eliminate any rubbing.
Old 02-10-2011 | 12:51 PM
  #23
Xnight's Avatar
I think that the 2.5 TF BB and maintaining my stock rims with the 295/70R18 terra grapplers which will be about 34.3 in diameter is exactly as far as i wanna go, spacers i'll definetly get the best out there, and that should do it, just have to get a reply from Northridge in regards to the price for the BB WITH shocks, their price shipped for the kit without the shocks was great but i prefer to replace the shocks. So we'll see. and will keep you all informed. unless someone here has some more input to add.....
Old 02-10-2011 | 01:06 PM
  #24
Xnight's Avatar
Well northridge4x4 just got back to me so, if i get 5 295/70R18 tires, the TF2.5 BB and 4 spacers at 1.5" i am still a couple of hundred below budget.....
Thank you all for the assistance, it made this a whole lot easier.
But please, stop by once in a while if you think i need anything else
Old 02-10-2011 | 01:12 PM
  #25
tattedfire's Avatar
Originally Posted by TripleJeep_99
Seriously price out a set of 16 or 17" rims with proper backspacing of your liking and a set of 33x12.50R16or17's and I will lay some scratch ($) that it will be cheaper than getting a set of 5 -18" tires and spacers. IMHO 33's will not look silly on a 2 or 2.5" and actually not terrible on a 3" lift like I have pictured below.
X2. Agree with this theory
Old 02-10-2011 | 01:19 PM
  #26
Xnight's Avatar
I will do the research... like i said before, i do like black rims, but i havent found those $50.00 ones mentioned before, maybe due to poor research, but i will look further. dont get me wrong i can make some serious cash back by selling my 18's but i may keep them just in case...... and im sorry but i would love to be closer to 34's, like everything else an extra inch is an extra inch..
Old 02-10-2011 | 04:15 PM
  #27
Ktonrider's Avatar
Originally Posted by nlam2001
Do you have a lift?
No lift yet, no rubbing lock to lock.
Old 02-10-2011 | 04:45 PM
  #28
Davesrb's Avatar
I went with stock Sahara 18's and Nitto's in 35x12.5r18. Used 1.5 wheel spacers. Here's before the lift:
And after a 2.5 Max Travel lift:
I need to adjust my steering stops a little bit. At full lock I have a little rubbing on the lower control arms.
Old 02-10-2011 | 06:45 PM
  #29
trick50's Avatar
Originally Posted by Xnight
I am so so friggen confused, will someone tell me if the Nitto terra grapplers in the 295/70R18 will fit my stock shara 18 inch rims?, and i mean without making the jeep dangerous, from what i gathered this tire size is a 34.
Tax money is going to a TF 2.5 BB, spacers if needed and 5 tires, i cant afford rims and i think 33s are gonna look silly and why just go up 1 inch.... but lets not get off the main question. believe you me i tried looking for a chart or something that wold tell me what the rim width should be for that tire, but with so many jeepers here, i figured i'd continue here.
Anyone?
yes they will fit, but you will definetly need spacers. without spacers if you try to turn your steering wheel more then 3/4 of the way you will be rubbing the actual sway bar. With 1.5" spacers you could actually run them with the stock suspension but you will rub your fenders if you wheel it
Old 02-10-2011 | 06:56 PM
  #30
nicksabellajk's Avatar
How was the drive with the spacers?
