View Poll Results: Should i spray paint my JK flat black?
Voters: 138. You may not vote on this poll
So I'm thinking spray painting my jeep...
if you want your jeep to look splotchy, have inconsistent paint thickness and poor adhesion, paint it with a spray can.
if you're set on painting it and want to do it at least half right, go buy or borrow a paint gun and a compressor. a can of spray paint will look like ass (unless you do some cool graffiti stuff).
good luck
good luck
good luck
good luck
https://www.jk-forum.com/forums/jk-show-tell-33/painting-jk-olive-drab-79400/
This Jeep actually won some awards for the paint, and it was ALL done with rattle cans. Just because it may sound stupid, doesn't mean it cannot be done correctly given enough time and effort.
A buddy of mine is anal about regular waxing which will protect it from 90% of trail bush in the NW. My stance though is just wear the scratches like a badge of honor. You can't wheel anywhere within a 100 miles of Seattle and not regularly get scratches. Let the trails apply the matte finish you want.
Flat black will show more scratches and damage then ur gloss paint. I wouldn't recommend a flat black vehicle for off road use. Your best bet is to get a flat black wrap.
DO NOT WET SAND!!! You will totally f@#k up your paint (especially since it is black). I wouldn't rattle can a flat black either. Flat black will appear uneven and splotchy- unlike the olive drab green. I would use a clay bar and see if that will lighten/eliminate the scratches. The ONLY way I would make my JK a satin black is with a paint gun and compressor. Buy hot rod black- and you can get a clear coat that will not add any gloss at all. JMO
I'm seriously considering sanding down the burrs off the fenders and coating them with some bedliner. Once I get a replacement rear fender, I'll experiment with my damaged one.
Sorry man, but that's just wrong info, and here's proof. This is the Jeep I was speaking of earlier.
https://www.jk-forum.com/forums/showthread.php?t=79400
Are you feeling okay Redneck?
I cant remember the name of it, but you should try that peel-off paint they make for cars. I believe its latex based, but its not meant to be permanent. Its meant to give you an idea of what your Jeep would look like in a certain color.
if done right it will come out well and hold up very nicely. go for it
