So I just got....
If you have time, try different pressures and see which you like best. I keep mine at about 26 or 27. Try 30 psi first, then let out a bit more if you still don't like it.
If your lift did not come with replacement front lower control arms, that will cause it to be a bit rough. You may need to add adjustable lower control arms later. That is what is making my ride if a little rough right now.
You're in the jeep money vortex now! Just Empty Every Pocket!
Thank you for the advice guys, really appreciate it! I hear you about the vortex Rocker. Just Emptied Every Pocket recently and Im already looking to make my next purchase.
I run 28 PSI on my 35" MTR Kevlars. It'll soften up the ride. But, aftermarket springs/shocks USUALLY are a bit stiffer than OEM ones on the road, might be the issue as well.
