Snorkel intake
#21
Air quality, denseness, and temperature aside- there's more "Water Proofing" that needs to be done. You can't just slap on a snorkel and jump in the deep end. I know on the TJ there's a bunch of area's that need silicone to protect Under hood electrical and I'd imagine the JK's being more technologically advanced there would inturn be more area's not so water friendly.
#22
breather lines as well. the TJ auto's had ridiculously short (and difficult to modify) breathers. i don't have my JK yet to look at them, but it is something else to address for deeper crossings.
#23
ok, wow, just read this thread, and couldnt help but reply. Snorkel are better then cold air intakes...which actually isnt a cold air intake. a normal system takes air fron under the wheel well, so its not cold, just not as hot. The snorkel system utilizes true air from outside the engine bay.
For those of you talking about dust, thats what a filter is for...duhhh. its not like you just slap a snorkel on there with no filter.
and the air flow part. while it might not be the most efficiant way of getting air to the engine, i promisse you wont notice the diffrence even if you had one or the other, you drive a jeep, its slow. now that being said, pick up a short straw and then a long straw and suck air through both, they you get the same amount of air, just as quickly.
#25
http://home.earthlink.net/~mmc1919/venturi.html
#26
![Smile](https://www.jk-forum.com/forums/images/smilies/smile.png)
The "Cold Air Intake will give you 15 horsepower cause it's colder" crowd is here to stay
![Big Grin](https://www.jk-forum.com/forums/images/smilies/biggrin.png)
Most people will see something that looks cool, and then try to justify it to themselves and others. How many people are going to ford water deep enough to need a snorkle that sits 6 feet off the ground? How many will actually do all the other modifications necessary to let the engine and electrical system run in those conditions?
If you were out actually trying to get from point A to point B, and you saw a river 5 feet deep, your first inclination should be to find a shallower spot to ford. Dunking your pumpkins isn't a terribly good idea, let alone your entire drive train.
And no. Having an eight foot long intake with 90 degree bends in it is horrible for volumetric efficiency. It will rob torque no matter how cold the air outside is.
-E
#27
snorkels were practical on Willys jeeps they had very little electronics to worry about., Your wasting your cash if you think its going to work on a JK
If you like the looks than go for it. But its not practical on newer jeeps.
#28
AHH, burnoulli's principal...yes, but his principal deals with a standard rate of air flow, not changing air flow rates, as you would when an engine reves. True, you will always get better air flow with bent piping then jagged angles, but in this case, you will not notice a diffrence between the 2, and as stated before, you get cleaner denser air, wich prolly makes up for the diffrence. i would have to work some math but i dont feel like doing it.
Here is a link of what a snorkel can do for your suv...hmmmmm looks like it has plenty of electronics on it being a early 80s vehical....![Smile](https://www.jk-forum.com/forums/images/smilies/smile.png)
http://video.google.com/videoplay?do...rkel+4x4&hl=en
#30
Bernoulli's Principle states that as the speed of a moving fluid increases, the pressure within the fluid decreases.
In other words, as the speed (rate) of flow changes, so does the pressure.
-E
