Snapped Front Axle Housing on Trail!! - suggestions?
Old 07-13-2015, 10:11 AM
  #31
Invest2m4's Avatar
Originally Posted by scafootballpro5
Where can you find just the housing? I can only find the full J8 assemblies for ~$5000
Here you go: Crate Axles. Axle Assembly made by Mopar. #P5160036
It is listed in the mopar catalog, so any place that can sell mopar should be able to get it. Everything is the same as the rubi axle except the tubes are a thicker wall. The tubes are .375" vs. .250" for the standard housing. For the price, it is a pretty good way to upgrade the housing. It can also be trussed with any D44 truss. If you can break that, it is time for a big boy axle.
Old 07-13-2015, 10:16 AM
  #32
MOPWR2U's Avatar
Originally Posted by ShutterBug
I'm sure you could find a D30 housing for <$500
I sold my Dana 30 axle, complete with all internal parts, outer axles, bearings, ball joints, brakes, the whole enchilada, for $200. It only had 74 miles of street use on it, and had never been in 4 wheel drive. And it took two months to find someone to buy it at that price. Dana 30s are a dime a dozen.
Old 07-13-2015, 11:00 AM
  #33
nthinuf's Avatar
Originally Posted by lkjk
Take anything Eddie says with a grain of salt.
Yeah, it was late. I threw it up there just to stir things up.
Originally Posted by jsnyda
But wouldn't sleeving most likely have prevented a catastrophic break like this? I could limp down on a bent housing theoretically?
As mentioned once or twice in that thread I linked, the sleeves did stop the housing from breaking at the normal location, where yours broke. But since the housing couldn't shatter there, it simply moved the break area down to where the sleeve ended, right near the diff.
Post 40 - the sleeved housing break
Post 59, 68 - eddies opinion on post 40, for what it's worth...
And for those who want to jump in with "but I'm not a hard-core wheeler!!!, I'll be ok!!!" (this is on the street with stock tires...)
https://www.jk-forum.com/forums/stoc...e-help-161915/
But, folks, this isn't a huge problem that each and every one of us is going to run into. it is just something to be aware of, good to know info so you can at least make some informed decisions...
Old 07-13-2015, 11:06 AM
  #34
james&jess's Avatar
I would sell my d44 for 250 for the housing
Old 07-13-2015, 01:49 PM
  #35
scafootballpro5's Avatar
Originally Posted by Invest2m4
Here you go: Crate Axles. Axle Assembly made by Mopar. #P5160036 It is listed in the mopar catalog, so any place that can sell mopar should be able to get it. Everything is the same as the rubi axle except the tubes are a thicker wall. The tubes are .375" vs. .250" for the standard housing. For the price, it is a pretty good way to upgrade the housing. It can also be trussed with any D44 truss. If you can break that, it is time for a big boy axle.
Alright thanks man! This may be in my near future. If I buy just the housing I would be able to keep everything else from a D30 correct? I would regear to 4.56 if I did but I could still keep the shafts and rotors with 5x5 bolt pattern?
Old 07-13-2015, 02:25 PM
  #36
Invest2m4's Avatar
Hmm, I'd say no. You'd need a different carrier and I'm not sure there is any option that does not include a locker as the center section is specific to the Jeeps. So, I'd guess you need locker and inner axle shafts.
Old 07-13-2015, 02:50 PM
  #37
lkjk's Avatar
If this is really the case wouldn't it be cheaper to just sleeve? I understand it's not gonna be 1:1 strength but pretty close, especially if they are weld in
Old 07-13-2015, 04:17 PM
  #38
Maertz's Avatar
Sleeves do nothing where the tubes are pressed in and plug welded at the dif. Parts wise truss makes alot more since cost wise. They also offer support for the weak factory arm mounts and such also on some options. Some sleeves also limit axles shafts wich to me doesn't matter as none are a true 35 spline like a d60 to my understanding. This dude needs a replacement at this point, sleeves are to late.
Old 07-13-2015, 04:54 PM
  #39
McKinney's Avatar
From what I have learned you need to truss it and avoid sleeves. If you break an axle shaft in a way this is too much twist the OD of the shaft will be greater than the ID of the sleeve leaving it a bitch to get out!
Artech Truss with outer C gussets and control arm skids is what I did on my front axle before I put bigger tires and wheeled it. Did the lift and axle at the same time.
Hopefully you got it off the trail OK. An ounce of prevention is worth a pound of cure
ID:	617772Click image for larger version
ID:	617773Click image for larger version
ID:	617774Click image for larger version
Old 07-13-2015, 05:36 PM
  #40
lkjk's Avatar
Yea, I know trusses are better than sleeves, no question.
My question is more - why would anyone buy that axle as an upgrade, assuming they didn't need it in a pinch like this.
The only reason I went sleeves over truss is install cost, night and day, although eventually i'll get a truss
Quick Reply: Snapped Front Axle Housing on Trail!! - suggestions?
