Snapped Front Axle Housing on Trail!! - suggestions?
Old 07-13-2015, 06:03 AM
  #21
jsnyda's Avatar
Originally Posted by Havok287
I see stuff like this and am worried truly about taking my jeep off-roading, is this truly something to be worried about if I just off-road maybe once a month or so? Nothing crazy. But I don't want to have to worry about going on a small trail and seeing this happen when I don't even do anything hardcore. I'm not very financially well off to consider upgrading to a pr44 or anything right now, but would like to know how I can avoid this at a reasonable cost. I'm on a d30 and 35s. Any insight would help, sorry for the thread jack.
Valid thread jack, and honestly its scary. I'm glad I wasn't wheeling alone! I always learn the important things on this thread *after I break something. In hindsight I should have sleeved it, its inexpensive and would probably have saved me this whole headache.
Old 07-13-2015, 06:19 AM
  #22
lkjk's Avatar
Originally Posted by nthinuf
Sleeves move the break from the normal location at the passenger side ca mounts to the end of the sleeve at the pumpkin. There should be a few in this thread:
https://www.jk-forum.com/forums/modi...ousing-137074/
Take anything Eddie says with a grain of salt. He only changed his tune because evo started selling sleeves. That said I have sleeves, but Eddie is still an idiot
Old 07-13-2015, 06:36 AM
  #23
4x4Jesus's Avatar
This is old info,
I wouldn't bother sleeving a 30 or 44 because the tubes can still bend at the differential. I had sleeves installed in my factory 44 and the tubes still bent. Best advice is to play with what you got and save up for a better housing. I now currently run a ProRock 44.
Old 07-13-2015, 07:08 AM
  #24
jsnyda's Avatar
Originally Posted by 4x4Jesus
This is old info,
But wouldn't sleeving most likely have prevented a catastrophic break like this? I could limp down on a bent housing theoretically?
Old 07-13-2015, 07:56 AM
  #25
MOPWR2U's Avatar
Best way to prevent this from happening, and even this isn't 100% certain, is to change to the 225/75R-16 street tires that front axle was designed to handle. Jeep under engineered the front axle on these JKs even for stock use. Add larger tires, and its just a matter of time before the front axle fails.
Old 07-13-2015, 09:06 AM
  #26
Invest2m4's Avatar
Exactly.
Old 07-13-2015, 09:27 AM
  #27
Havok287's Avatar
That really is a shame, ok. Well I guess I can just hope to get as much out of it as possible and start saving for the upgrade haha. Thank you!
Old 07-13-2015, 09:44 AM
  #28
scafootballpro5's Avatar
Originally Posted by Invest2m4
While a no frills option, mopar sells the J8 housing for around $800. It's the Rubicon D44 with thicker axle tubes.
Where can you find just the housing? I can only find the full J8 assemblies for ~$5000
Old 07-13-2015, 09:58 AM
  #29
ShutterBug's Avatar
There is a guy in Cincinatti that sells complete Mopar D44 axles (minus calipers, I believe) for $1800.
My intention is to replace my front with this after it is gusseted and trussed (and maybe sleeved for good measure).
I'm sure you could find a D30 housing for <$500
Old 07-13-2015, 10:08 AM
  #30
james&jess's Avatar
If you were in Hawaii I would give you a great deal on my 2014 d44 rubicon front axel
Quick Reply: Snapped Front Axle Housing on Trail!! - suggestions?
