SmrtTire?
Old 09-18-2007 | 09:41 AM
zekisson's Avatar
Default SmrtTire?
Anyone used the smarttire tire pressure monitoring system? I got one of these and it's driving me mad : 1st it got signal from all four sensors and worked, then lost one , then two and now it shows only one! Manual doesn't say how to reset the unit.. Any ideas?
I deflated and inflated in hope to get the signal / learn mode to occur but with no luck
Old 09-23-2007 | 02:14 PM
BaltChief's Avatar
I'd be interested to know what to do when you go wheelin.....do they chime at you all day till you air back up?.....I hope not
Old 09-24-2007 | 03:19 AM
zekisson's Avatar
Nope they won't as you can set the limit of the low air alarm! (from 0 to 15 psi). However I'm very disapointed as yet I can't get the signal from all 4 sensors, maybe the MTC baja are two thick to passs through the FM signal?
Old 09-24-2007 | 09:26 AM
driley's Avatar
We have the SmarTire system on our motorhome. Shortly after installing it, it would not pickup the rear tires. It ended up being a bad antenna or antenna wire. Once that was replaced it all worked fine.
Old 09-24-2007 | 09:39 AM
cjsdad's Avatar
What signal r u getting, cuz I have an 08 sahara 4dr and I haven't seen anything yet. Haven't looked either, but there r no lights that r lit on panel.
Old 09-24-2007 | 11:32 AM
driley's Avatar
The original poster has an aftermarket tire monitoring system from SmarTire - http://www.smartire.com/
It does not come as original equipment on any Jeep.
Old 09-24-2007 | 11:35 AM
cjsdad's Avatar
oh, ok. I was thinking that might be what is on the 08s. They have some air pressure on them.
Old 09-24-2007 | 11:43 AM
USAF_GroundRat's Avatar
What a shitty website. No pictures of anything... I at least like to see the product before I consider a purchase. Crimeny. How many tires can the automotive version monitor? I was thinking all five tires and even monitoring the on-board air pressure system. What say ye?
After downloading the manual... it looks like you could do 10 sensors.
Old 09-24-2007 | 11:53 AM
zekisson's Avatar
The product is of high quality, I don't know what I did and I lost the signals from all tires. The monitor can give you temp and pressure on as many as 18 tires! depending on how many snesors you want to ad.
I just need to figure out how to reset the system
Old 09-24-2007 | 01:31 PM
BaltChief's Avatar
I have pressure sensors on mine. They were original eqipment. They let you know when the air pressure is low. Both by audible and visual light in the dash.
