Smittybuilt G.E.A.R tailgate
Poly nuts grip from the back side and compress, and now i am out in garage and there's like 3 layers of metal so i cant go with poly nuts there's not enough grip. and i am back to the self tappers which are not stainless so i got some black stainless screws. So on a 2012 they have a door stay and a black cover i have to go over and make holes for the stay
Originally Posted by augichef
I screwed the top left corner then pulled it tight and then drilled the next screw in. I also stuck 3m heavy duty Velcro strips around the edges between each self tapping screws. I got a lot of weight on mine and I haven't had any issues with sagging. I also add a long strip of Velcro across the top so I can drape a black cloth over my gear to somewhat hide it when the top is off.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=244260"/>
Originally Posted by Evo35
For those with the arm that comes out with the door. I attached over the product. As you can see, I had an issue with some gap. Its the only place I have that problem.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=244864"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=244865"/>
All done and id say the quality is good and install was easy if you use stainless like i did make sure you run a metal screw first after pre drill.Attachment 244889
Attachment 244864
Attachment 244865
Attachment 244864
Attachment 244865
nice mod on the LED light. what did you tap into or how is it powered?
