Smittybilt G.E.A.R. Overhead Console
You can put the top back on as usuall. It's easy enough to close the inside latch's over the cosole, just cant get your fingers in behind them to open without pushing the middle up a bit.
Doesn't it leak?
If you're not fastening the front and rear center locks on the hard top, doesn't it leak? I've already got problems every time it rains. I'm not opposed to a one-piece freedom top, I think I can handle that if I could take the pieces apart after its physically off of the jeep.
I didn’t know there was a certain order to reinstall i just lay them on the do everything up if it leaks i just tighten the back ones and that fixes it
sorry if this is a repeat of another thread but I asked once and got sent here. I am hoping for a review/opinions of the product. I have soft top so I wont mind the trouble in this thread. Recommended or no? Thanks
Also, is this thing compatible with the Mopar Sunbonnet (their silly name for the great safari top)? That uses the footman loop to secure a lanyard from the middle of the top to reduce flapping. You can see it in this pic ...
I like the lanyard idea i’ll give that a try
as far as the Mopar Sunbonnet being compatible I’d have to say no because you remove the footman loop and use the holes to bolt the console on ,but if you can tie it to the console some how I guess you could make it work
Originally Posted by woodie427
... if you can tie it to the console some how I guess you could make it work
