Small Lift
Small Lift
I have a 07 Sahara unlimited which has the factory larger tires. I would like to just get it lifted a couple inches. Its more for aesthetics then heavy wheeling or putting larger tires on it as i plan to retain the current tires. I'd like to do it the correct way and it will be due for some shocks in the near future anyway. So who make s a descent kit for this (2-3")? I think i would like to avoid the spacer thing.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
If you decide to go higher and/or add wheels at a later stage, then you can probably get a good chunk of your money back by selling the levelling kit (not that it's a bank breaker anyway). Teraflex also do a version of the levelling kit that uses springs instead of spacers. Some good info. here;
https://www.jk-forum.com/forums/show...t-Lift-for-the
The problem you are going to run into with coils is that they generally give more lift than advertised. (ie - a spacer is listed at 2.5", it gives 2.5". A coil is listed as 2.5", it gives 3.5-4") And as you go higher, you will want to add more components to bring you back to a 'stock' ride.
A positive side effect would be that as you go higher, those small stock tires will look worse and worse to you, so you'll end up with bigger shoes...
