Sliders and a body lift?
Your Jeep has points on it where the body is bolted to the frame. On a 2 dr its 10 total 5 on each side of the vehicle. I think there are 12 on an unlimited. If you add a body lift you are putting spacers on each of the points to raise the Jeep 1,2 or 3 inches depending on what you want to gain. I don't know if there are even 3 inch lifts for jeeps but 1 and 2 are often used. By putting on a body lift you raise the body off of the frame giving you room for bigger tires and space so the tires dont rub on your Jeeps body.
Most Jeeps have suspension lifts but if you dont want to spend the money on one of those or want to deal with drive shaft angles and only want a small amount of room for bigger tires go with the body lift. Its cheaper and easy to do yourself.
I have a 2 1/2 inch suspension lift and am putting on a 1.25 inch body Rough Country ( their lift is actually a small amount bigger than a standard 1 inch lift ). I run 35 inch tires and will post a pic this week showing my Jeep prior to the body lift and after it.......
Here is mine. 2.5" Teraflex coil lift with 1" coil spacer in rear. 1.25" rough country body lift with 35 inch tires. I have poison spyder tub armor on there and am almost done welding on my own enhanced rubi rails. This was all done because of my body lift. So now i have lots of room for my 35's to stuff yet don't have to worry as much about drive angles and the need for adjustable control arms. As well as the cost side as my lift was ~$500 the body lift was ~$150 rear spacers ~$50 so I am up around 4ish inches for low price and nice handling. The rubi rails were chopped as well as my pinch seam, got the rails for $125 and then fabed up some rails for those as well as I will beef up the rubi rail's mounts a bit. So these should provide decent body protection along with the poison spyder tub armor. I will post pics of the rubi rails on when I am done. Here is it in the mean time though. Hope this helps others see an option for rocker protection with a body lift.
I am planning on getting rock rails/sliders,( either Shrockworks, PJ's, or LOD's.) I am also thinking about a 1" body lift down the road.
Shrockworks asks if you have a body lift when you order them. Is this because they mount to the frame?
Since LOD's will mount to the frame I assume they will need to know as well.
If this is the case, do I have to decide on whether or not I am doing a body lift before I buy sliders?
