Slider decision.. Rockhard or VKS?
#41
Looks good. My tub damage was done at pretty much the same spot but higher up just underneath the door hinge with the ACE/rubi setup.
#42
#46
Only issue i can see is the provided bolts are short. Add the thickness of the slider and rail its hard to tell if the bolt taper clears the frame. Longer bolts will ensure the actual threads clear the frame. I thought these were 3/8x16 but they are not.
#49
This thread should be titled "Frame mounted vs. body mounted"
Comparing these two brands is like comparing apples to oranges.
Look at Poison Spyder. They offer their Rocker Knockers in both frame mounted and body mounted.
I'm going RockHard simply because I don't want to drill my frame. They suit my needs, look great, have a nice finish, and are 100% made in the USA.
#50
Yup looks like my LOD sliders, almost exactly. I even had mine custom made to have the step go all the way across the top like the ones above. Mine is a 4 door though. Lod only makes a small step in front of the doors and I didn't like that so, I called them and had them change that for me.
