SkidRow engine/tranny skid. Oil change question.
I went to Harbor Freight and bought a screw on drain plug with tube attachment. Essentially, you replace your drain plug with this and a cover. When you want to drain, you screw off the drain cover, and screw on the drain tube -- it has a spring that pushes in the center of the drain plug to let the oil drain out as the drain tube is screwed on. No mess afterwards.
I was kiddin about the lazy part.....and I agree like THREE MILLION PERCENT about your R&D comment. Stuff like this really pisses me off. These companies are ROBBING people like you and me with PISS POOR workmanship and R&D. I'm glad you posted this, cause I know to steer clear of Skid Row. I already knew it though, cause somebody else was unhappy with something they made on here too. How much of the skid would have to be cut to get the hole the right size?
I still like my Skid Row and Im glad I got this one over the others, a little issue like that, that a 99 cent funnel or pop bottle can fix, is not worth loosing sleep over
i want to get that skid plate and my idea for a fix was to install one of them oil drain valves. i don't have one now because without a skid there is a good chance of snapping it on a rock and i'll have a real problem. with the skid plate there, no worries and it'll make it easy to drain.
i think the messy part of changing the oil is the filter. i'd love to find a relocation kit.
if you find a source please let me know, that would solve the problem in a heart beat
but seriously once you perfect the funneling process it isnt that hard to change the oil
takes me about 15 minutes, start to finish
I was planning on ordering this. Sounds like I will have to get the quick valve drain as well or make a mess on my garage floor. Any other issues with Skid row. Yes I realize that the Rockhard would have the same issue but I am interested in skidrow.
Dude, dont go ripping on Skid Row for something like that. I think just about any skid plate, including Rock Hard (talk about robbing you for $100 more) is going to have this issue unless you have a HUGE hole in the skid to drain the oil. The oil shoots out far, especially if its warm, then as it gets down to the last quart or so, it doesnt shoot out hardly at all, then when your down to a trickle, it drops straight down, so that hole would need to be like 10" big in order to not get any oil on the skid! I dont know about you, but I sure dont want no huge hole in the bottom of my skid plate exposing parts that its suppose to protect. So I think they did do their R&D just fine, by making a hole big enough to allow you to use some kind of funnel or deflector, but no too big that it make the skid week, or lets a big rock, sticks and so on to poke a hole in your oil pan.
well... the deflector piece they have in there helps.... but its still not mess free. But at least the oil is pretty much contained to the skid cut out and deflector. Its about a 3/4 shop rag clean up I have thought about cutting out a 2 liter soda bottle to fit in there and contain the mess a little better, but honestly its not really that bad. I cant even imagine the kind of mess the guys with the skid row plate make
This is kind of wierd, i have not had a single complaint from any of the 3 jeeps dealers that have changed to oil in RubyDoo (got the free oil change maintance package), And after every change i check under there and its always been clean, maybe because it flat instead of up on ramps?
