Skid plates?
#21
They're painted black. Artec also makes a crossmember with built in long arm mounts. Might want to check if that's something beneficial for you.
#23
How long have you had the skids? Any abuse/damage to report?
Any chance you can post a few more pictures of your skid setup?
#24
Another vote for the Synergy HD system.
I have it, I like it. Creates a flat belly, integrated X-member and stand alone gas tank skid create more clearance under than most other manufacturers systems, is very robust.
Admittedly it is spendy.
I also did control arms skids, and rear shock skids/relocation brackets, along with Poison Spyder e-vap skid.
So far so good on AZ rocks running 2" lift and 35's.
Everyone that sees the underside of the rig (when 3-wheeling etc.) is very impressed with the skid setup.
#25
Another vote for the Synergy HD system. I have it, I like it. Creates a flat belly, integrated X-member and stand alone gas tank skid create more clearance under than most other manufacturers systems, is very robust. Admittedly it is spendy. So far so good on AZ rocks running 2" lift and 35's. Everyone that sees the underside of the rig (when 3-wheeling etc.) is very impressed with the skid setup.
#26
I've looked into the mount. It will work with my current set up and probably make it stronger but I'm not sure I want to go thru the process of modifying my current brackets. How long have you had the skids? Any abuse/damage to report? Any chance you can post a few more pictures of your skid setup?
#27
I guess so far it has probably done its job. Lol.
When are you going to be in Moab? Maybe we could meet up for a bit so I can get a look. Any chance you will be there this weekend?
You don't need to get pictures.
Im mostly interested in the rear bracket holding up the transfercase skid and the flag type nuts that are put into the crossmember (I know you won't be able to get a picture of these). Did you get an Hd crossmember? I couldn't see any bolts hanging down in the previous pictures.
#28
#29
10 days.... I guess so far it has probably done its job. Lol. When are you going to be in Moab? Maybe we could meet up for a bit so I can get a look. Any chance you will be there this weekend? You don't need to get pictures. Im mostly interested in the rear bracket holding up the transfercase skid and the flag type nuts that are put into the crossmember (I know you won't be able to get a picture of these). Did you get an Hd crossmember? I couldn't see any bolts hanging down in the previous pictures.
Yeah, I installed the Artec HD Crossmember as well. The only bolt that hangs down is the OEM bolt on the driver side frame that helps hold up the tranny skid.
#30
Former Vendor
Rockhard4x4 will your engine/tranny skid work with the Rancho exhaust spacer mod?
http://www.quadratec.com/Assets/Installation/163654.pdf
