Which size Nitto?
Old 06-13-2014, 05:35 AM
  #31
Bypass's Avatar
Originally Posted by LidLess07X
Today I encountered some Douche weaving in and out traffic in a jacked up F150 and driving like some ricer from the Fast and Furious. I ended up next to him at the next light and sure enough, Rockstars and Nittos. I thought of what you said in this post and laughed a little to myself, and thought about how ironic it was to see that after this post.
All day every day.
Old 06-16-2014, 12:26 PM
  #32
MAG00's Avatar
Generally the terrain around here is simple rolling hills, mud, rutted fire roads, etc. Not much rocks around here, unless I go out of town to an off road park that has some.
I didn't figure there being much height difference, but I thought maybe the more narrow tire would be a little less weight and a little easier on my current 3:73 gearing. I figured the wider tire would take a little more power to push down the road (both on and off).
I know that for my day to day driving and that with a large majority of my use being on road that something like the GY Duratrac would probably be a better general use fit for me. However, I have stuck in my head that I want the MT due to looks and when I get off road in the mud I don't want to be spinning "slicks" (read that as a tire not clearing out).
Old 06-16-2014, 10:47 PM
  #33
Blue Fish's Avatar
Default 7.5
I run 285 75r17 NittoClick image for larger version
ID:	560198Click image for larger version
ID:	560199 Trail grapplers on stock 2012 Rubicon 7.5" wide rims. They look great with 2" lift and no spacers needed tucked nicely under the fenders. There's only .75" clearance at the rear of the rock guard rail with these 34.1" tall tires. They have a nice smooth and surprisingly quiet ride with great off road traction.
Old 06-17-2014, 06:26 AM
  #34
MAG00's Avatar
Originally Posted by Blue Fish
I run 285 75r17 NittoAttachment 560198Attachment 560199 Trail grapplers on stock 2012 Rubicon 7.5" wide rims. They look great with 2" lift and no spacers needed tucked nicely under the fenders. There's only .75" clearance at the rear of the rock guard rail with these 34.1" tall tires. They have a nice smooth and surprisingly quiet ride with great off road traction.
What gears are you running and how does your rig handle the tires i.e. power, mpg, etc.? Is the ride stiff due to the E rating on these tires?
Old 06-17-2014, 08:11 AM
  #35
twoxstreem's Avatar
Originally Posted by Bypass
People around me by the hundreds run them. Every oilfiled worm takes their first check and buys whatever 4x4 their credit will allow and they promptly gear it out with Rockstars and Nittos. I've seen them on jeeps used for crawling, street driving, mud riding, etc, etc, etc. The universally known worst issue with them is tread life. Their "cool" patterns and compounds do not lend themselves to a long, quiet, good wearing life. Buy what you want and learn the hard way. The only people that "love" them are people that don't know any better, or have just recently bought some and don't want to accept they made a bad choice.
This guy is the worst type to be giving information on a forum.
I have 35" nitto trail grapplers and which have about 50% of the tread left at 26,000 miles.
This guy has no idea what his is talking about. I run them at 28lbs and they ride smooth, soft and quiet.
Old 06-17-2014, 08:14 AM
  #36
MAG00's Avatar
I'm kind of leaning towards the 285/75R17 since the 315/70R17s are 13" wide. I think that wide of tire will be harder on my front end and I don't necessarily need that wide of tire. Plus my wells are only 8.5" wide.
The only reason I was looking at it was due to the D rating in lieu of the 285/75R17 E rating. However, since my rig is a 4 door I don't know that the E rating will make much of a difference. Just don't need to run them at a high psi. What do ya'll think?
Old 06-17-2014, 10:32 AM
  #37
meep97's Avatar
I still think the d rated tires would be the best. You probably won't see the 13" they say. You will probably end up in the 12" range. The e rated tires will still be to stiff even on a 4 door.
Old 06-17-2014, 10:57 AM
  #38
Jeepstin12's Avatar
Originally Posted by MAG00
I'm kind of leaning towards the 285/75R17 since the 315/70R17s are 13" wide. I think that wide of tire will be harder on my front end and I don't necessarily need that wide of tire. Plus my wells are only 8.5" wide. The only reason I was looking at it was due to the D rating in lieu of the 285/75R17 E rating. However, since my rig is a 4 door I don't know that the E rating will make much of a difference. Just don't need to run them at a high psi. What do ya'll think?
I have a JKUR with e rated Nitto trails. Hard ride, stiff tire. Looking at going to d range on the next set. Not bad, but rough on some bumps.
Old 06-17-2014, 10:27 PM
  #39
Blue Fish's Avatar
Stock gears, the new Penstar motor with 6spd manual has plenty of power, the handling and ride are fine haven't checked the mpg yet.
Old 06-18-2014, 07:51 AM
  #40
Bear_13's Avatar
I was debating whether to do the 285/75/17 or 295/70/17 and am very happy with the 295/75/17. I think that if I had gone with the 285s I would have been upset. The only problem with the 295s is that you hit your air dam at full turn in reverse.
Quick Reply: Which size Nitto?
