Side Steps for JKU
1 Post
Side Steps for JKU
My wife is vertically challenged and has a hard time entering my JKU (2012 2.5 lift with 35s). I currently have the factory side step, which is to high for her to get in comfortably. Granted I am keeping my mileage lower, since she always prefers to take our other vehicle. I have been looking to replace the factory side step with something that is low enough to offer assistance getting in and can possibly double as a slider. I have seen several variations and want to know what other have done.
What did you install and what is the measurement from bottom of door entry? Pics would be great!!
Are the adjustable steps any good? How about the automatic one (does it also act as a slider)?
Oh, and she didn't like the idea of the stir-up.. Not sure why?
I have the Rugged Ridge Slider. Works good as a step, but not the best slider. I've beat mine up pretty well, though. Try the ACE slider, it seems to work well, esp if you add some anti skid tape to step on.
1 Post
The ACE does look solid, although it looks like it is installed under the Rubi slider? http://www.aceengineeringandfab.com/...Door_p_15.html
Rock slide engineering, step sliders. I have these installed. They are great rock sliders, and have a step that drops when you open the door. My four year old can now get into my JKU with three inch lift without help. Highly recommended.
Go with ace . They are great guys and make a great product. I have seen there shop a few times (only 20mins from my house) I will almost exclusively buy there products because how well they treat there customers.
1 Post
Just took a look at them. Very cool, but but also $$$$. It is compatible to the other electric ones I have seen, but including the slider too. I can't seem to justify the cost though, there would be too many things on the list ahead. I could probably do without the automatic if the step was adjustable or could be put on or taken off when needed.
Rugged Ridge and Smittybuilt are pretty much the same design. They bolt up to the body bolts(sort of). Their main downfall is they are made in China of pretty cheap steel. I wouldn't buy them again. The Ace is a better option, IMO. They also mount to the body bolts. They sit below the bottom lip of the body. If you have Rubi Rails, they sit below them, just barely. Pretty much the same height as the stock steps. If you go off road at all, you're not going to want too low of a step, you'll just tip it off, or it'll get hung up and you'll get stuck. I have seen a remove able step, that you can take off the slider when you wheel. I can't remember the brand though.
